Currpt_God Posted October 28, 2007 Share Posted October 28, 2007 on a NA build what would be the best ratio to use for? using wisco pistons and eagle rods/ full skunk 2 head thanks guys Link to comment Share on other sites More sharing options...
cranny Posted October 28, 2007 Share Posted October 28, 2007 all depends on what kind of engine dude. Link to comment Share on other sites More sharing options...
Currpt_God Posted October 29, 2007 Author Share Posted October 29, 2007 lsvtec...... in a 92 civic hatch Link to comment Share on other sites More sharing options...
VTEC4L Posted October 29, 2007 Share Posted October 29, 2007 USE 12.1 YOU'LL LOVE IT. I HAVE 12.1 WITH PRO 2 CAMS AND VALVETRAIN AND I REV TO 9,800RPMS WITH NO POWER LOSS. VTEC4L Link to comment Share on other sites More sharing options...
Currpt_God Posted October 29, 2007 Author Share Posted October 29, 2007 is the higher the ratio the better? i am going with pro 3 cams full pro valve train....... so should i go higher then 12 to 1? like a 13.5 to 1 or even 14 to 1? Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted October 29, 2007 Share Posted October 29, 2007 stick to 12:1, 13:1 is pushing it for street.... 14:1 + if your going alcohol... also the topic title should be changed to compression ratio, not piston ratio..... Link to comment Share on other sites More sharing options...
VTEC4L Posted October 29, 2007 Share Posted October 29, 2007 MAKE SURE THAT YOUR PISTON TO VALVE CLEAREANCE IS GOOD BECAUSE VERY EASILY CAN YOU STRIKE THAT VALVE WITH HIGH COMPRESSION. ALSO DON'T MISS A GEAR BIG GUY PRO3 AND HIGH COMPRESSION EASY TO BLOW IT GOOD LUCK. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 29, 2007 Share Posted October 29, 2007 please make sure you take CAPS off. you don't have to yell to get yoru point across. Link to comment Share on other sites More sharing options...
Currpt_God Posted October 30, 2007 Author Share Posted October 30, 2007 so do you guys think that i should stick to the pro 2? or just go with the pro 3? and which do you guys think would be a better ratio... the 12 - 1 or the 13 - 1 in either a aries or wisco pistons and eagle rods? Link to comment Share on other sites More sharing options...
VTEC4L Posted October 30, 2007 Share Posted October 30, 2007 First of all I would like to apologize for having the caps on! Anyways I am using Pro 2 with 12to1! Its great idle is a little inconvinient but if you want to make some more power use the Pro 3 I am sure that they are beastly but you will have to give up some driving comfort for them. As for compression the more the better but fuel becomes a major part in it and realiability becomes a ?. Everyday driving with 13 to 1 or more no going to happen. Link to comment Share on other sites More sharing options...
Pballer2005 Posted October 30, 2007 Share Posted October 30, 2007 First of all I would like to apologize for having the caps on! Anyways I am using Pro 2 with 12to1! Its great idle is a little inconvinient but if you want to make some more power use the Pro 3 I am sure that they are beastly but you will have to give up some driving comfort for them. As for compression the more the better but fuel becomes a major part in it and realiability becomes a ?. Everyday driving with 13 to 1 or more no going to happen. talk like yoda you do Link to comment Share on other sites More sharing options...
VTEC4L Posted October 30, 2007 Share Posted October 30, 2007 Sorry its just that I have been working on B Series motors for the last 6years. Link to comment Share on other sites More sharing options...
Kegger Posted October 30, 2007 Share Posted October 30, 2007 Agreed, don't go above 12.1:1 on a DD. You'll have to run race gas or alcohol injection to be worth a damn above that. Personally I'd say 11.5-12.0 to 1 is gonna be your best bet. Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2007 Share Posted October 31, 2007 11.5:1 w/stage 2 = more reliable , still fast 12.5:1 w/stage3 = little less user friendly but in reality , it will start every time you turn the key too , lol , and it will be faster , lol. if your gonna go 12:1 , mine as well go 12.5:1. Link to comment Share on other sites More sharing options...
VTEC4L Posted October 31, 2007 Share Posted October 31, 2007 Get a good tune and you will love it. Instant reponse Pro cams are also pretty good on the mid range also I have beaten H-22 Hatches from a mid rpm roll Link to comment Share on other sites More sharing options...
Pballer2005 Posted October 31, 2007 Share Posted October 31, 2007 it seems like a high comp ratio+heavily cammed+well tuned car would be a very fun street car. i personaly would love the torque. i miss my truck :( Link to comment Share on other sites More sharing options...
cranny Posted October 31, 2007 Share Posted October 31, 2007 torque comes from displacement , period. so upping your displacement is the only way to get torque really in these engines. or any for that matter. Link to comment Share on other sites More sharing options...
Pballer2005 Posted November 6, 2007 Share Posted November 6, 2007 torque comes from displacement , period. so upping your displacement is the only way to get torque really in these engines. or any for that matter. i thought that raising comp was a given to raise torque significantly? i still need to learn alot... Link to comment Share on other sites More sharing options...
IVhorsemenmotorsports Posted December 10, 2007 Share Posted December 10, 2007 Agreed, don't go above 12.1:1 on a DD. You'll have to run race gas or alcohol injection to be worth a damn above that. Personally I'd say 11.5-12.0 to 1 is gonna be your best bet. I wouldn't push more than 11.5:1 with 91 octane. Any more and you would have to retard the timing so much that it would be pointless to run that compression. You could run a cam with extreme overlap to bleed off some pressure but the dynamic compression while in the high rpms would cause it detonate. You can retard the timing but you will lose the power you are trying to gain with the compression. If it's a daily driver I would go with the stage 2 cams for drivability Link to comment Share on other sites More sharing options...
