sprtbiker Posted October 24, 2007 Share Posted October 24, 2007 I posted this question a while ago but all the solutions didn't solve the problem. Problem: My steering wheel jerks as I drive. If I am going very slow (<5 mph), the jerk happens at a certain point of the wheel turning. As I go faster (10-20 mph) the jerk gets faster. But when I am driving fast (40+ mph) there steering wheel is vibrating a bit but not to effect driving. Fixes tried: I have rotated and balance my tires. Didn't fix the problem Is it the rack and pin? I have replaced the right CV joint recently and the left one was replaced 5 years ago. Appreciate the feedback. Link to comment Share on other sites More sharing options...
Kegger Posted October 24, 2007 Share Posted October 24, 2007 Check and make sure all the hardware is tight, control arm mounts, ball joint crown nuts, all of it. If it still happens, check to make sure you're ball joints haven't let go. If thats good, then wheel bearings, then wheels. Make sure they are straight. Link to comment Share on other sites More sharing options...
cranny Posted October 24, 2007 Share Posted October 24, 2007 you need an axle it sounds like. that or you have a warped wheel or hub. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 24, 2007 Share Posted October 24, 2007 i'm gonna go with a bad hub since the tires were balanced. Link to comment Share on other sites More sharing options...
95exd16z6 Posted October 30, 2007 Share Posted October 30, 2007 ive unfortunately hit a couple curbs and now my steering wheel wobbles like a mofo. i kno that the wheels are bent. hopefully nothing else. if you fixed the problem please tell me what it was Link to comment Share on other sites More sharing options...
TheJGB3 Posted February 6, 2008 Share Posted February 6, 2008 The problem could be brake related (sticking calipers) or it could be "torque pull" (caused by the CV joint) Link to comment Share on other sites More sharing options...
