deycallmemc Posted October 16, 2007 Share Posted October 16, 2007 I have never done an engine swap so i feel no fear in asking some questions. Would it be possible to swap a 2000 honda civic si engine and transmission for that of a 97 ex? I own the ex and wanted to get the si e/t. Any other information i would need to know if this was possible? Thanks for any help you can give me. Link to comment Share on other sites More sharing options...
Pballer2005 Posted October 16, 2007 Share Posted October 16, 2007 yeah its possible and a popular swap i don't know the details but i'm pretty sure something will come up on the search. Link to comment Share on other sites More sharing options...
adamEj6 Posted October 16, 2007 Share Posted October 16, 2007 same exact shell so it will be all plug and play pretty much Link to comment Share on other sites More sharing options...
cranny Posted October 16, 2007 Share Posted October 16, 2007 you need the Si rear mount bracket , Si A/C bracket , which doubles as torque mount. you need any 94-01 shift linkage. you can reuse your civic passenger tranny mount. you need any 94-01 passenger side front torque mount. and you need drivers side mount off Si as well. youl need an OBD2B to OBD2A conversion harness. youl reuse the harness thats in your car. youl need to wire vtec. use search. Link to comment Share on other sites More sharing options...
VTEC4L Posted October 20, 2007 Share Posted October 20, 2007 Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Link to comment Share on other sites More sharing options...
Ben. Posted October 20, 2007 Share Posted October 20, 2007 Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Onestly don't do it. You will be unhappy and spend a good amount in purchasing the motor and swapping it. Go B-18c or Type R its a little more pricing but you will be happier in the long run. B-16's or SI are the worst for tourque and make less power to the wheels. Most cars on the street are hardly running stock engines so a stock B-16 will get hurt. But thats my opinion! Um. NOWAI. Link to comment Share on other sites More sharing options...
VTEC4L Posted October 20, 2007 Share Posted October 20, 2007 Um. NOWAI. WHAT? Its the truth Link to comment Share on other sites More sharing options...
