juliopr69 Posted October 13, 2007 Share Posted October 13, 2007 I know very little about cars so i'm hoping someone could help. i have a 93 civic and the day before yesterday i notice that the car doesn't start up like it used to. then yesterday when i when to start it ,,it sounded weak ( rerrrrrrr short pause rerrrrrr lol ) it wasn't like it was try ing to start right-a-eay but after 2 or three time it finally started up. then if i shut it off and start it up agian it would start up with no problem. But if i leave it off 2 or 3 hours and try to start it up , it would do the same thing as the begining. is there anything i can to to pin point the problem. this morning it won't start at all ,, HEELLPP MMEE Link to comment Share on other sites More sharing options...
Kegger Posted October 13, 2007 Share Posted October 13, 2007 Battery or alternator are going bad. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 13, 2007 Share Posted October 13, 2007 I concure sir. The battery or alternator sounds to be goind bad. Pull the both of them and take them to napa and have them check to see if either/both are bad. Link to comment Share on other sites More sharing options...
cranny Posted October 13, 2007 Share Posted October 13, 2007 if you have no ALT light on when the car is running , most likely the ALT is good. clean your grounds and battery posts. Link to comment Share on other sites More sharing options...
James Matteu Posted October 14, 2007 Share Posted October 14, 2007 I concur, battery. Link to comment Share on other sites More sharing options...
Blizzard Posted October 14, 2007 Share Posted October 14, 2007 if you have no ALT light on when the car is running , most likely the ALT is good. clean your grounds and battery posts. That's always a good first move. Link to comment Share on other sites More sharing options...
juliopr69 Posted October 16, 2007 Author Share Posted October 16, 2007 thanks guys it was the battery Link to comment Share on other sites More sharing options...
