98_coupe_ex Posted October 8, 2007 Share Posted October 8, 2007 right now i have a sohc 1.6l in my civic. would new pistions, rods, ecu and turbo be worth the money or should i look into getting a dohc and going from thier? Link to comment Share on other sites More sharing options...
AccordHEART Posted October 8, 2007 Share Posted October 8, 2007 If you plan to boost a SOHC motor, or any motor for that matter, You should build the head. New springs, retainers, valves, etc. And I'm not talking OEM. Link to comment Share on other sites More sharing options...
98_coupe_ex Posted October 8, 2007 Author Share Posted October 8, 2007 ok so which would be more cost efficent.... bascilly i looking for around 250 hp so what would be the best route to get that much if not more hp? Link to comment Share on other sites More sharing options...
AccordHEART Posted October 8, 2007 Share Posted October 8, 2007 If you're not looking for reliable, Just boost the hell out of the stock motor. If you are looking for reliable, drop in an H22 Type-S and get some minor bolt ons. Link to comment Share on other sites More sharing options...
Ben. Posted October 9, 2007 Share Posted October 9, 2007 Orrr you keep your air conditioning and go with a b-series swap and spray/boost it. Link to comment Share on other sites More sharing options...
airjordan223 Posted October 9, 2007 Share Posted October 9, 2007 you can get 250 hp boosting a sohc. it would be better with a b series, but the cost of swapping in a new motor and then turboing that isnt worth it. theres a couple pinned threads at the top of the "engine tuning uprgrads and swaps" forum with good info about turbos and building a motor. Link to comment Share on other sites More sharing options...
CleanGSR Posted October 9, 2007 Share Posted October 9, 2007 Definately keep the SOHC. Forged pistons, new rods and probably about 14psi on a T3/T04B and you should hit your 250whp goal reliably. This would all come at the cost (or less) as a B series swap and much less than an H22 swap and the turbo SOHC would have a lot more power. Link to comment Share on other sites More sharing options...
