Miamishatchback02 Posted October 7, 2007 Share Posted October 7, 2007 Ok i have a 92 hatch back with a d15z1 engine and its 1.5 vtec slow as hell so iam planing on building me a nice ls/vtec turbo mottor but i dont know what type of harnes i need to get the b18b1 to work once its converted to vtec with the b16 vtec head or if i can use mine help me out pls. Link to comment Share on other sites More sharing options...
cranny Posted October 8, 2007 Share Posted October 8, 2007 you need an OBD1 engine , and you need to use the harness thats already in your car , it will all plug right in like it was meant to be there. youl have to run a few wires through the firewall from the ecu , knock sensor(located on back of engine) , pressure switch power , vtec solenoid signal. they pin into A4(VTEC SOL) , D3(KS) , D6(PRESSURESWITCH). get a plug off another junk car , and OBD1 plug , pop sides open , using needle nose , simple pull them straight out , leave enough wire to splice into. once you have 3 pins , pop sides open , place one in A4 , D3 , D6. and wire them to where i told you. your in. Link to comment Share on other sites More sharing options...
