matryx Posted October 6, 2007 Share Posted October 6, 2007 Hi, I got a 1996 GSR and my car is starting to act up. I'm not sure what is the problem but I think its probably the clutch. When I start the car and try to be it into first or any gears it won't work. It just doesn't want to go in. I turn it off and go through the gears fine. Start it up again and put it into first, when letting off the clutch the car shakes like its going to stall out while I'm giving gas still. While this is happening I try to put it in neutral but its difficult also. Anybody have any idea what the problem is here. The problem is hard to describe. Since I can't drive it anywhere I won't be able to get it to a shop and why I come here first to get some opinions of the problem. Link to comment Share on other sites More sharing options...
cranny Posted October 6, 2007 Share Posted October 6, 2007 check your clutch fluid. Link to comment Share on other sites More sharing options...
matryx Posted October 6, 2007 Author Share Posted October 6, 2007 I actually did check my clutch fluid a while ago and pored some more in there. I also recently had the transmission fluid changed like 2-3 weeks ago. Link to comment Share on other sites More sharing options...
Hatch92 Posted October 6, 2007 Share Posted October 6, 2007 how many miles are on the car? or if there was a motor/tranny swap how many miles on the swap? Link to comment Share on other sites More sharing options...
Hdelsol95 Posted October 6, 2007 Share Posted October 6, 2007 Hi, I got a 1996 GSR and my car is starting to act up. I'm not sure what is the problem but I think its probably the clutch. When I start the car and try to be it into first or any gears it won't work. It just doesn't want to go in. I turn it off and go through the gears fine. Start it up again and put it into first, when letting off the clutch the car shakes like its going to staff out while I'm giving gas still. While this is happening I try to put it in neutral but its difficult also. Anybody have any idea what the problem is here. The problem is hard to describe. Since I can't drive it anywhere I won't be able to get it to a shop and why I come here first to get some opinions of the problem. WHAT IS STAFF OUT? u mean choke out? check fluid first if that is good then its ur clutch most likely, u can drive it if u know how did it for a few weeks while i ripped a spring off my clutch disc Link to comment Share on other sites More sharing options...
Ben. Posted October 6, 2007 Share Posted October 6, 2007 Stall..out. Link to comment Share on other sites More sharing options...
matryx Posted October 6, 2007 Author Share Posted October 6, 2007 yeah I mean't stall out. Can't really drive it actually. I'll be restarting the engine at every stop and thats if I can even get it into gear. Time to look for a new clutch. What do you guys recommend for a daily drive gsr with basic bolts on Link to comment Share on other sites More sharing options...
Hdelsol95 Posted October 6, 2007 Share Posted October 6, 2007 u might wanna get lightwieght flywheel and sense its mainly bolt ones i dont see why u would need a better clutch.. Link to comment Share on other sites More sharing options...
matryx Posted October 6, 2007 Author Share Posted October 6, 2007 well I am planning later on to rebuild my engine and upgrade some parts so I'm thinking getting a better clutch would be a good idea so I don't have to worry about it later. Of course I haven't done enough research yet to know what kind of things I want to upgrade later on, but got some ideas of reading some engine rebuild posts. Link to comment Share on other sites More sharing options...
Hdelsol95 Posted October 6, 2007 Share Posted October 6, 2007 aight man well do ur research its real simple to install a new clutch, just takes a big of manhandling without a lift lol, i had to crawl on the ground with my tranny on my chest then lift it into the car 3 times, damn those plastic alignment tools Link to comment Share on other sites More sharing options...
1994 TEG Posted October 17, 2007 Share Posted October 17, 2007 i was haveing the same problem with my tranny and it was my clutch disc and i put a exedy stage 1 in my car. my buddy had one in his car and it was boosted and he had it in there for over 2 years now. Link to comment Share on other sites More sharing options...
cranny Posted October 17, 2007 Share Posted October 17, 2007 i dont think your clutch itself is the issue. seems its not disengaging properly , check your slave and master cylinder for leaks and weeping. when a clutch gets bad , it slips. unless your pressure plate or disc crap the bed , meaning broke in some way. any noises at all? what sound change when stepping/letting off the clutch in neutral with car running? Link to comment Share on other sites More sharing options...
SIR_VTEC Posted October 17, 2007 Share Posted October 17, 2007 i dont think your clutch itself is the issue. seems its not disengaging properly , check your slave and master cylinder for leaks and weeping. when a clutch gets bad , it slips. unless your pressure plate or disc crap the bed , meaning broke in some way. any noises at all? what sound change when stepping/letting off the clutch in neutral with car running? Thats exactly what I was about to say Cranny!?! are you like standing next to me or something lol... but yea anyway if its engaging while the car is off and not engaging while your car is on then most likely its the plate, but you would want to check your master and slave cylinders to make sure thats not f-ed, because its just the cylinders than thats an easy fix if you can do it yourself...if not its going to cost you a couple hundred to get it done. Link to comment Share on other sites More sharing options...
