Pyrorocketeer Posted October 5, 2007 Share Posted October 5, 2007 So I was changing my plugs today, and noticed a bit of smoking from under the hood when i started my engine after I was done.... I searched around a bit, and couldn't find anything that could be leaking, so I took off the exhaust manifold heat shield, and look what I found.... I knew I could smell exhaust from somewhere when I got on the throttle semi-heavy, but couldn't figure out from where.... So here are my options... Used stock exhaust manifold.....or aftermarket. I'm not really in it for the power gains, but if I could bump up my fuel efficiency slightly I'd go with the after market. any suggestions on what to do, and or what to get without breaking the bank? Link to comment Share on other sites More sharing options...
Xeryon Posted October 5, 2007 Share Posted October 5, 2007 heat tape Link to comment Share on other sites More sharing options...
James Matteu Posted October 5, 2007 Share Posted October 5, 2007 ditto on the tape until you can get a used header from the boneyard Link to comment Share on other sites More sharing options...
