Currpt_God Posted October 5, 2007 Share Posted October 5, 2007 first problem - so the b16 in my 92 civic is acting weird........... it changes its idel all the time.... one min it will run at 1 k rpm and the next it will be at 1600 and the next at 200 about to die.....its been doing this for about3 weeks now......... second problem - compared to a couple different b16 swaps in the same year that i ahve drove ...... it feels like mine does not have the same amount of power...... i mean i was just racing a 91 civic with a warn out single cam zc enigine and he can keep up with me and im shifting right at 8200....... i do oil changes every 3000 miles and run full synthic oil............ any suggestions guys? Link to comment Share on other sites More sharing options...
AccordHEART Posted October 5, 2007 Share Posted October 5, 2007 1st problem - Sounds like your IAC valve. 2nd problem - Could be a lot of things. Link to comment Share on other sites More sharing options...
Currpt_God Posted October 5, 2007 Author Share Posted October 5, 2007 ok so where should i start? Link to comment Share on other sites More sharing options...
AccordHEART Posted October 5, 2007 Share Posted October 5, 2007 Replace your Idle Air Control valve, That will probably fix the idle problem. It's common on Hondas. As far as being slow, Your engine might just need a tune up. Are there any other problems? Like spitting, missing, running rich, lean, etc. Link to comment Share on other sites More sharing options...
Currpt_God Posted October 5, 2007 Author Share Posted October 5, 2007 every once in a while when i start it up it will kill its self if i dont give it gas right away.... and then it will not start again for another like 20 - 30 mins? Link to comment Share on other sites More sharing options...
AccordHEART Posted October 5, 2007 Share Posted October 5, 2007 Could be a fuel problem, or a spark problem. Check your plugs. It might be your fuel pump. I'm not sure. Not too much on repairs and things of that nature. Just going by prior knowledge/experience. You might try a fuel system cleaner, Or seafoam. Link to comment Share on other sites More sharing options...
Currpt_God Posted October 5, 2007 Author Share Posted October 5, 2007 alright thanks for the info Link to comment Share on other sites More sharing options...
cranny Posted October 5, 2007 Share Posted October 5, 2007 definitely. sounds like it needs a tuneup badly. new plugs , wires , rotor button and dizzy cap. PCV valve. sounds like your timing belt might be getting slack worn if its got that little of balls. when was it done last? timing belt and valve adjustment and tuneup , it will work mint again. Link to comment Share on other sites More sharing options...
