dez2121 Posted October 3, 2007 Share Posted October 3, 2007 battery light stays on. I did battery & alternator test yesterday, and both are good. I've checked all my connections & plugs,and there fine. It drove fine earlier today until i shut it off, then it would not start. After car set for lil while it started & died. Had to jumpstart car & noticed idle fluctuating. Tried to drive and throttle fought me & bogged down before i could leave driveway. When i turned the key back forward the ecu started making a weird clicking noise, even after i removed the key from the ignition it continued for another 15-20 seconds. please help! Link to comment Share on other sites More sharing options...
cranny Posted October 3, 2007 Share Posted October 3, 2007 sounds almost like a relay of some sort. check your grounds dude , they are probably corroded. Link to comment Share on other sites More sharing options...
dez2121 Posted October 4, 2007 Author Share Posted October 4, 2007 da ground was one of the problems, also i have a short in my alternator. thanx for da help. Link to comment Share on other sites More sharing options...
