Kelkou Posted September 25, 2007 Share Posted September 25, 2007 Just wondering what injector size i should use for my stock b16, or what size the stock injectors are. cylinder number 3 isnt getting fuel, but all others are, and, its the injector, swapped injectors with number 4, and cyl 4 didnt fire. So im letting the injector soak in injector cleaner right now, hoping itll fix it. i noticed the very bottom (part that is in the IM) has a crack, would this affect its ability to spray? So i was just curious as to the injector size, in case it needs replacing. B16A thanks. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted September 25, 2007 Share Posted September 25, 2007 240cc Link to comment Share on other sites More sharing options...
Kelkou Posted September 25, 2007 Author Share Posted September 25, 2007 thanks also any ideas on how to clean this injector? other than letting it soak in cleaner? Link to comment Share on other sites More sharing options...
Kelkou Posted September 25, 2007 Author Share Posted September 25, 2007 bump Link to comment Share on other sites More sharing options...
bseriesboy95 Posted September 25, 2007 Share Posted September 25, 2007 i also have a b16a but its not stock and am finishing up on all my mods now not sure what size injectors to use. b16a block 20 over 20 over pistons eagle rods stock crank b16a head port n polish new valve train ( retainers, dual springs, titanium retainers) stage 2 cams ported manifold and throttle body 80 to 70mm custom kit aem fuel rail, pressure reg walboro 225lb fuel pump powerchamber intake, jdm 4-1 header dc sport exhaust act clutch short shifter crank pulley looking 11 to 1 to 11.5 to 1 i also need some input on which spark plugs i should use thanks. Link to comment Share on other sites More sharing options...
