Jmpage84 Posted September 23, 2007 Share Posted September 23, 2007 Hey guys, I just recently moved to the Dallas area from Maryland and I haven't really had the need to drive my car lately since I don't know where anything is and my step-mom and I work for the same company in Downtown so I just ride with her to work. Lately, my rex hasn't been running right at all. I changed the spark plugs and replaced the fuel filter, hoping it would fix the problem. Unfortunately, it hasn't. From idle to about 2250 rpms, the car seems to have no power, but once it hits 2250, it runs like normal. Any help is much appreciated. Thanks Link to comment Share on other sites More sharing options...
crxtacy Posted September 23, 2007 Share Posted September 23, 2007 check the timing on the car ? Link to comment Share on other sites More sharing options...
Jmpage84 Posted September 23, 2007 Author Share Posted September 23, 2007 Would having it sit for a few weeks make it lose timing? Link to comment Share on other sites More sharing options...
SiR REX Posted September 23, 2007 Share Posted September 23, 2007 does it do it as soon as u start the car or does it start after its been running for a while? Link to comment Share on other sites More sharing options...
Jmpage84 Posted September 23, 2007 Author Share Posted September 23, 2007 If I start it when the engine is cold, it runs normal, but once it warms up, it starts bogging. Link to comment Share on other sites More sharing options...
crxtacy Posted September 24, 2007 Share Posted September 24, 2007 check the pcv valve.see if the check valve is stuck. Link to comment Share on other sites More sharing options...
89highfuelcrx Posted February 27, 2008 Share Posted February 27, 2008 I'm having this same problem but its the other way around... I just bought my 89 crx and it runs...ok... up until 3200 rpm then it sounds like its misfiring or bogging and it wont go any faster.... any ideas on that???? I replaced the o2 sensor and checked plug wires and new plugs so far Link to comment Share on other sites More sharing options...
Kegger Posted February 27, 2008 Share Posted February 27, 2008 You are in safety mode. Bad dizzy most likely, borrow a working one from someone and see if that corrects it. Link to comment Share on other sites More sharing options...
89highfuelcrx Posted February 27, 2008 Share Posted February 27, 2008 You are in safety mode. Bad dizzy most likely, borrow a working one from someone and see if that corrects it. Dizzy????????? Link to comment Share on other sites More sharing options...
slosol Posted February 27, 2008 Share Posted February 27, 2008 distributor Link to comment Share on other sites More sharing options...
