99blkcivicb16 Posted July 24, 2007 Share Posted July 24, 2007 Hey guys im swaping a 2000 b16a2 into my 99 civic ex and have a few questions that would like help with if some has done this before and could help me out let me know email me. thanks Link to comment Share on other sites More sharing options...
Kegger Posted July 24, 2007 Share Posted July 24, 2007 The B16 came stock in the 1996-2000 Civic Si. It's gonna be an easy swap. Link to comment Share on other sites More sharing options...
99blkcivicb16 Posted July 24, 2007 Author Share Posted July 24, 2007 The B16 came stock in the 1996-2000 Civic Si. It's gonna be an easy swap.ya know i still have a few questions that i was wondering about so i was seeing if anyone has done this yet. Link to comment Share on other sites More sharing options...
lifemalfunction Posted July 24, 2007 Share Posted July 24, 2007 ya know i still have a few questions that i was wondering about so i was seeing if anyone has done this yet. ask away Link to comment Share on other sites More sharing options...
99blkcivicb16 Posted July 24, 2007 Author Share Posted July 24, 2007 ask away OK SO DO I NEED ANYTHNG SPECIAL FOR THE A/C TO WORK? DOES MY CAR NEED B16 AXELS TO HAVE ABS? DO I NEED A ECU FROM A B16 TO MAKE IT WORK OR WILL MINE WORK ? JUST A FEW FOR NOW. Link to comment Share on other sites More sharing options...
Kelkou Posted July 24, 2007 Share Posted July 24, 2007 Caps lock is not necessary to get some answers.... Usually when you order a motor it comes with the ECU.... Link to comment Share on other sites More sharing options...
99blkcivicb16 Posted July 24, 2007 Author Share Posted July 24, 2007 Caps lock is not necessary to get some answers.... Usually when you order a motor it comes with the ECU.... it wasnt to get crazy about just was on anyway it didnt come with it thats why im asking. Link to comment Share on other sites More sharing options...
cranny Posted July 25, 2007 Share Posted July 25, 2007 The B16 came stock in the 1996-2000 Civic Si. It's gonna be an easy swap. actually its only 99-00 , 2 years. yes you need the ecu out of a 99-00 civic Si coupe. yes you will need not B16 , but B series period ABS axles. ABS axles have the splines in the wheel ends for the ABS sensor. in order for your A/C to work , youl need A/C brackets off a 99-00 civic Si as well. pretty sure it doubles as an engine mount. im sure your A/C pump will bolt up to B16 brackets but im not 100% on that. Link to comment Share on other sites More sharing options...
adamEj6 Posted July 25, 2007 Share Posted July 25, 2007 yeah the a/c pump will bolt up for sure Link to comment Share on other sites More sharing options...
99blkcivicb16 Posted July 25, 2007 Author Share Posted July 25, 2007 actually its only 99-00 , 2 years. yes you need the ecu out of a 99-00 civic Si coupe. yes you will need not B16 , but B series period ABS axles. ABS axles have the splines in the wheel ends for the ABS sensor. in order for your A/C to work , youl need A/C brackets off a 99-00 civic Si as well. pretty sure it doubles as an engine mount. im sure your A/C pump will bolt up to B16 brackets but im not 100% on that. ok thanks bro ill work on getting those parts. Link to comment Share on other sites More sharing options...
lysol Posted July 25, 2007 Share Posted July 25, 2007 ok thanks bro ill work on getting those parts. B-series a/c brackets do not bolt on to d-series compressors. There are two ways you can go about this, One will cost alot more than the other and pain in the ass. 1.) Your engine should have came with an A/c compressor and bracket attached already to the engine. To get the a/c working you have to discharge your freon, replace dryer,vaccum system and recharge it with r-134a. If you do the pricing. It will cost you more than option 2 will. 2.) head over to a dealer or salvage yard and pick you up a del-sol Dohc V-tec or CR-V A/c bracket. These brackets will save you money and will bolt on to your stock d-series compressor with out discharging you a/c system. If you have the money To spend, Option 1 is your answer. If you don't like others don't. My choice is option 2. Hope this helps good luck Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted July 25, 2007 Share Posted July 25, 2007 B-series a/c brackets do not bolt on to d-series compressors. 2.) head over to a dealer or salvage yard and pick you up a del-sol Dohc V-tec or CR-V A/c bracket. These brackets will save you money and will bolt on to your stock d-series compressor with out discharging you a/c system. Makes no sense....you contradicted yourself........so, which one buddy? Link to comment Share on other sites More sharing options...
lysol Posted July 25, 2007 Share Posted July 25, 2007 Makes no sense....you contradicted yourself........so, which one buddy? It's clearly option 2...................... Link to comment Share on other sites More sharing options...
cranny Posted July 26, 2007 Share Posted July 26, 2007 i dont get it either , your saying D series AC pumps wont bolt to B series brackets , yet you say the solution( #2) is to get B series brackets? lol. hmmmm. you know what dude , if your swap comes with an AC pump and all brackets , than just disconnect the lines going to the D series pump , which will discharge your R134a , than bolt the lines(hopefully lines are the same) to the B16 AC pump , and get it charged again , its cheap man. you can get cans of R134a and charge it yourself. takes like 25 ounces or somin. Link to comment Share on other sites More sharing options...
lysol Posted July 26, 2007 Share Posted July 26, 2007 i dont get it either , your saying D series AC pumps wont bolt to B series brackets , yet you say the solution( #2) is to get B series brackets? lol. hmmmm. you know what dude , if your swap comes with an AC pump and all brackets , than just disconnect the lines going to the D series pump , which will discharge your R134a , than bolt the lines(hopefully lines are the same) to the B16 AC pump , and get it charged again , its cheap man. you can get cans of R134a and charge it yourself. takes like 25 ounces or somin. Yes The del-sol V-tec and the CR-V brackets are b-series. 96-97 Del-sol vtec,99-00 si, and 94-01 intergra ls,gs and gsr have the same A/C brackets. Exclude 90-93 integras because they don't have the engine mount support thing. 94-95 del-sol Vtec came out with an entirely different bracket as did the 97-01 CR-V to use the d-series compressor. I know this because i did the research and Im running a CR-V bracket to retain my a/c in my civic. If you have time to compare the d-series bracket to your b-series bracket you will see the difference. It sure beats discharging then charging ac and hope lines bolt on to the b-series compressor. Link to comment Share on other sites More sharing options...
99blkcivicb16 Posted July 26, 2007 Author Share Posted July 26, 2007 Yes The del-sol V-tec and the CR-V brackets are b-series. 96-97 Del-sol vtec,99-00 si, and 94-01 intergra ls,gs and gsr have the same A/C brackets. Exclude 90-93 integras because they don't have the engine mount support thing. 94-95 del-sol Vtec came out with an entirely different bracket as did the 97-01 CR-V to use the d-series compressor. I know this because i did the research and Im running a CR-V bracket to retain my a/c in my civic. If you have time to compare the d-series bracket to your b-series bracket you will see the difference. It sure beats discharging then charging ac and hope lines bolt on to the b-series compressor. so your sayin all i need is the a/c brackets off a 97-01 crv or 94-95 bracket and it will hook up to my bseries compressor? or i can use my d series compressor? Link to comment Share on other sites More sharing options...
lysol Posted July 26, 2007 Share Posted July 26, 2007 so your sayin all i need is the a/c brackets off a 97-01 crv or 94-95 bracket and it will hook up to my bseries compressor? or i can use my d series compressor? Use the cr-v bracket because you can find it easier than the del-sol Vtec. It will bolt on to your d-series compressor. You will not have to discharge your a/c system. All you have to do when swaping engines is unbolt compressor from the d-series engine. Tie strap the compressor to the side. Say goodbye to the d-series engine and yank it out. Intall b-series engine and bolt on the cr-v a/c bracket. Unstrap compressor, bolt it on to the cr-v bracket. and your done. So just junk the b-series compressor and the bracket it came with and you will not have to get freon all over the place. Link to comment Share on other sites More sharing options...
