zimmy709 Posted July 24, 2007 Share Posted July 24, 2007 ok, my car is now turbo, and overheating is now a problem in traffic as my fan is not turning on. i have no idea why. The relay is fine, no blown fuses, the fan works like a champ when i directly wire it, and i jumped the fan switch on the thurmostat housing with a wire thinking the switch may be bad and it still didnt turn on. now wtf is up with that. does anyone have any ideas? i am running a 9 5integra secondary fan as my only rad fan because its the only one that will fit, but the plug is the same and from time to tome it works. so.... i dont get it. ANY IDEAS???? Quote Link to comment Share on other sites More sharing options...
93blacklx Posted July 24, 2007 Share Posted July 24, 2007 Just run a power wire for it to a toggle switch its getto but it works. a buddy of mine had to do the same thing Quote Link to comment Share on other sites More sharing options...
Xeryon Posted July 24, 2007 Share Posted July 24, 2007 I don't even had a modified car and my fan sensor just gave it up the other day. Rather then screw with it I'm just going to wire a toggle switch under the dash out of sight. Just leave it off and flip it on when you see that you are getting hot, or leave it on all the time and flip it off in colder weather so you get a little more heat. Quote Link to comment Share on other sites More sharing options...
zimmy709 Posted July 26, 2007 Author Share Posted July 26, 2007 i think my connection of the fan to the harness is the problem. i was playing with the connection between the two and it just kinda came on, so i may just cut out the connector and solder the wires together. Quote Link to comment Share on other sites More sharing options...
93blacklx Posted July 26, 2007 Share Posted July 26, 2007 sounds like a good idea Quote Link to comment Share on other sites More sharing options...
