Kelkou Posted August 12, 2007 Author Share Posted August 12, 2007 so we're havin trouble removing the axles. (cant think of the name of the part but i can explain) the 1 1/4 inch bolt that is on the hub is being a bitch, we went through 2 breaker bars yesterday.... Bought some liquid penetration gunk stuff to loosen it up, used a torch, going to get another breaker bar and try again after using the gunk spray 3 times overnight. hope thjis works.. any other suggestions? Link to comment Share on other sites More sharing options...
Ben. Posted August 12, 2007 Share Posted August 12, 2007 As in.. The nut that basically locks the hub to the axle? Or is it an actual bolt you're referring to? Most of the one's I ever dealt with were simple. Link to comment Share on other sites More sharing options...
coolcat467 Posted August 12, 2007 Share Posted August 12, 2007 yea a breaker bar should do it Link to comment Share on other sites More sharing options...
Xeryon Posted August 12, 2007 Share Posted August 12, 2007 i had same issue with my accord. you just need a bigger breaker bar and a pipe. get a 3/4 ratchet and add another 3-4 feet of pipe to the end of the ratchet and it should pop right off. Link to comment Share on other sites More sharing options...
Velocifero Posted August 12, 2007 Share Posted August 12, 2007 i had same issue with my accord. you just need a bigger breaker bar and a pipe. get a 3/4 ratchet and add another 3-4 feet of pipe to the end of the ratchet and it should pop right off.a strong air gun should work too. Link to comment Share on other sites More sharing options...
