civicturbocharger Posted July 12, 2007 Share Posted July 12, 2007 I want to know if the 99 si bottom block crank sensor will fit into the obd zero block???? because i need a new block and this was the only one i found for a good deal... I want to know because will it pass smog???? Plz..reply anyone with any knowledge about motors... thanks.. Quote Link to comment Share on other sites More sharing options...
cranny Posted July 12, 2007 Share Posted July 12, 2007 (edited) the blocks are the same mechanically , but different sensor wise. the sensor your referring to , im assuming its the CKF , crank fluctuation sensor , built into the oil pump , located next to crank on timing belt side. yes your 99 b16 oil pump will work on your new block. but some sensors are different on the block. nothing you cant work around with some reading and most likely lengthening a few wires to reach somewhere else. Edited July 12, 2007 by cranny Quote Link to comment Share on other sites More sharing options...
civicturbocharger Posted July 12, 2007 Author Share Posted July 12, 2007 the blocks are the same mechanically , but different sensor wise. the sensor your referring to , im assuming its the CKF , crank fluctuation sensor , built into the oil pump , located next to crank on timing belt side. yes your 99 b16 oil pump will work on your new block. but some sensors are different on the block. nothing you cant work around with some reading and most likely lengthening a few wires to reach somewhere else. Do you know if it will pass smog???? Quote Link to comment Share on other sites More sharing options...
VR17 Posted August 1, 2007 Share Posted August 1, 2007 Do you know if it will pass smog???? you would need to change the OBD 0 sensor to OBD 2. just buy one from honda or something.. Quote Link to comment Share on other sites More sharing options...
civicturbocharger Posted August 23, 2007 Author Share Posted August 23, 2007 you would need to change the OBD 0 sensor to OBD 2. just buy one from honda or something.. Is that the CKF sensor that the buddy above is talking about???? Quote Link to comment Share on other sites More sharing options...
cranny Posted August 23, 2007 Share Posted August 23, 2007 no. you already have the CKF , its built into your 99 oil pump. i was talking about the sensors on the back of ther block. Quote Link to comment Share on other sites More sharing options...
civicturbocharger Posted August 23, 2007 Author Share Posted August 23, 2007 no. you already have the CKF , its built into your 99 oil pump. i was talking about the sensors on the back of ther block. yes, i got that replaced, I swap out the one in the 99 to the obd 0 block. Now the question is that do i need to swap out the obd 0 sensor to obd II sensor??? Quote Link to comment Share on other sites More sharing options...
guythatknowsnothing Posted August 23, 2007 Share Posted August 23, 2007 you would need to change the OBD 0 sensor to OBD 2. just buy one from honda or something.. already answered Quote Link to comment Share on other sites More sharing options...
