VitalSpeed_CRX Posted July 3, 2007 Share Posted July 3, 2007 Sup , Just wondering if anyone has info on my OBD-0 wire harness. Trying to figure out what my OEM wire codes are. I have the jumpers for OBD-0 to OBD-1 about to do my own harness conversion just not sure what the color codes are. Honda 89 HF. Thanks. Quote Link to comment Share on other sites More sharing options...
VitalSpeed_CRX Posted July 9, 2007 Author Share Posted July 9, 2007 22 Views and still no help .. you guys are great....................... NOT.... Quote Link to comment Share on other sites More sharing options...
Pyrorocketeer Posted July 9, 2007 Share Posted July 9, 2007 how about those 22 ppl didn't have the answer to your question moron. people are so impatient these days. Quote Link to comment Share on other sites More sharing options...
cranny Posted July 9, 2007 Share Posted July 9, 2007 (edited) OBD0 DPFI to MPFI Comparison Pinouts DPFI MPFI Pin# Wire Color Function , Wire Color Function A1 Yellow 2 Aux Injector , Brown #1 Injector A2 Black 1 Main Relay/Ground , Black 1 Main Relay/Ground A3 Yellow 1 Aux Injector , Red #2 Injector A4 Black 2 Main Relay/Ground , Black 2 Main Relay/Ground A5 Red 2 Main Injector , Light Blue #3 Injector A6 Green Purge Cut Off Solenoid Valve (Coil) , Green Purge Cut Off Solenoid Valve (Coil) A7 Red 1 Main Injector , Yellow 1 #4 Injector A8 Yellow 3 Sedan LX (A/T only) A10 Red EGR Solenoid Control Valve (Coil) (A/T only) A11 Blue/Yellow EACV (Coil) , Blue/Yellow EACV (Coil) A12 Green/Black 2 Main Relay , Green/Black 2 Main Relay A13 Yellow/Black 2 Main Relay , Yellow/Black 2 Main Relay/Injector Resistor Box A14 Green/Black 1 Main Relay , Green/Black 1 Main Relay A15 Yellow/Black 1 Main Relay , Yellow/Black 1 Main Relay/Injector Resistor Box A16 Brown/Black Ground , Brown/Black Ground A17 A18 Black/Red Ground , Black/Red Ground Pin# Wire Color Function Wire Color Function B1 White/Green Hazard Fuse , White/Green Hazard Fuse B2 Orange Tandem Control Solenoid Valve , Blue 1 Fast Idle Control Solenoid Valve B3 Yellow A/C Clutch Relay , Yellow A/C Clutch Relay B4 Yellow/Green Radiator Fan Relay , Yellow/Green Radiator Fan Relay B5 White/Yellow Alternator , White/Yellow Alternator B6 Green/Orange Check Engine Warning Light , Green/Orange Check Engine Warning Light B7 Green/Orange Position Console Switch (Park, Neutral) , (A/T only) B8 Blue/Red A/C Switch , Blue/Red A/C Switch B9 B10 Orange Crank Angle Sensor B11 Green/Black A/T Shift Position Console Switch (Drive) , (A/T only) B12 White Crank Angle Sensor B13 Blue/White Main Relay , Blue/White Main Relay B14 Blue 2 To Yellow, To Alternator Blue 2 Alternator B15 White 1 Ignitor Unit White 1 Ignitor Unit B16 Yellow/Red Speed Sensor Yellow/Red Speed Sensor B17 White 2 Ignitor Unit White 2 Ignitor Unit B18 B19 Green/Red Electric Load Detector Green/Red Electric Load Detector B20 Brown Ignition Timing Adjusting Connector Brown Ignition Timing Adjusting Connector Pin# Wire Color Function Wire Color Function C1 Orange Crank Angle Sensor Blue/Green Cylinder Position Sensor C2 White 4 Crank Angle Sensor Blue/Yellow Cylinder Position Sensor C3 Orange/Blue TDC Sensor Orange/Blue TDC Sensor C4 White/Blue TDC Sensor White/Blue TDC Sensor C5 Red/Yellow TA Sensor Red/Yellow TA Sensor C6 Red/White 1 TW Sensor Red/White 1 TW Sensor C7 Red/Blue Throttle (Position) Angle Sensor (TPS) Red/Blue Throttle (Position) Angle Sensor (TPS) C8 Yellow EGR Lift Valve Sensor C9 Red/White 2 PA Sensor Red/White 2 PA Sensor C10 Green/White 3 Brake Switch Green/White 3 Brake Switch C11 White 1 MAP Sensor White 1 MAP Sensor C12 Green/White 2 EGR Lift Valve Sensor/Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor Green White 2 Pa Sensor/Ignition Timing Adjusting Connector/TA Sensor/TPS Sensor/TW Sensor C13 Yellow/White EGR Lift Valve Sensor/Pa Sensor/TPS Sensor Yellow/White Pa Sensor/TPS Sensor C14 Green/White 1 MAP Sensor Green/White 1 MAP Sensor C15 Yellow/Red MAP Sensor Yellow/Red MAP Sensor C16 White 3 O2 Sensor White 3 O2 Sensor Edited July 9, 2007 by cranny Quote Link to comment Share on other sites More sharing options...
VitalSpeed_CRX Posted July 9, 2007 Author Share Posted July 9, 2007 Thanks! Quote Link to comment Share on other sites More sharing options...
TS John Posted July 10, 2007 Share Posted July 10, 2007 Cranny rockin' it hardcore.... ... as is his custom. Quote Link to comment Share on other sites More sharing options...
