beanstalk805@hotmail.com Posted July 3, 2007 Share Posted July 3, 2007 have a 98 gsr and i was doinga really in depth detail on it which involved pressure washing the motor, after this on my way home (5 miles) it began to misfire and check engine light was flashing. when i got home i opened up the distributer cap and let it sit overnigt hoping it would evaporate all the moisture. tHe next morning I noticed the a nipple on the evap puge control solenoid was cracked. so i replaced it and reset the ecu. When i started it up it was cool for a little bit, but then it started misfiring again and check engine light blinking again. Someone please help! Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 3, 2007 Share Posted July 3, 2007 try spraying WD-40 inside the distrbutor cap .remove the plug wires and check if its wet too. About the WD-40,don't ask . I was skeptical myself when someone told me to do this and it worked. but try that . Quote Link to comment Share on other sites More sharing options...
beanstalk805@hotmail.com Posted July 3, 2007 Author Share Posted July 3, 2007 try spraying WD-40 inside the distrbutor cap .remove the plug wires and check if its wet too.About the WD-40,don't ask . I was skeptical myself when someone told me to do this and it worked. but try that . well the wierd thing is that when i turned it on there was no cel. then afeter maybe 30 sec. it came on and started idling really rought when i rev it to like 2k, it runs fine but it's when its idling. i'll try the wd-40 but then will i have to reset the ecu again? Quote Link to comment Share on other sites More sharing options...
eg9-civic Posted July 3, 2007 Share Posted July 3, 2007 take your spark plug wires off your plugs and look down in the hole and see if there is water in there. there probably is so take a vacume and tape a straw onto it. Quote Link to comment Share on other sites More sharing options...
beanstalk805@hotmail.com Posted July 3, 2007 Author Share Posted July 3, 2007 Well it hasnt been around water for like a month my reg is up and i've been getting stuff done to it, so do think there may still water in there? how would they get wet does the plug cover not keep water out? Quote Link to comment Share on other sites More sharing options...
Rick B. Posted July 3, 2007 Share Posted July 3, 2007 dude, i had water get down into my spark plugs and my gsr was running on 3 cylinders for a month before i figured out what the problem was. it sucked cuz i was only as fast as a prelude during that time. Quote Link to comment Share on other sites More sharing options...
2Boosted Posted July 3, 2007 Share Posted July 3, 2007 Check to make sure all your wires are connected to the dizzy correctly Quote Link to comment Share on other sites More sharing options...
eg9-civic Posted July 3, 2007 Share Posted July 3, 2007 if its not water sitting on top of your spark plugs its something with the distributor. Quote Link to comment Share on other sites More sharing options...
