Repsol Posted July 2, 2007 Share Posted July 2, 2007 When I start my car up in the morning..it goes to about 2200 rpm for idle. Sometimes it'll go from that down to 1500 and back up. It will do it like 7 times in a row or just once. I'm pretty sure it's the IAC valve causing this. Anybody know where I can get a new one? Quote Link to comment Share on other sites More sharing options...
Repsol Posted July 4, 2007 Author Share Posted July 4, 2007 Guess nobody knows where? Quote Link to comment Share on other sites More sharing options...
TS John Posted July 4, 2007 Share Posted July 4, 2007 It's pretty normal for a car to idle high when you first start it, especially when it's cold. What does it settle down to, and after how long? Quote Link to comment Share on other sites More sharing options...
Repsol Posted July 4, 2007 Author Share Posted July 4, 2007 like 5 seconds? it'll go up, then down, up then down, up then down, It's annoying. It hasn't been doing it much lately. *knocks on wood* It does it more when it's cold outside. Quote Link to comment Share on other sites More sharing options...
TS John Posted July 4, 2007 Share Posted July 4, 2007 Yeah, if it's that brief it's prolly nothing to worry about. My last del sol did it and so did my rex. This one prolly does but I have only had it for a month so far so I dunno. When an engine first starts up it's not running exactly as it should, so it's generally a good idea to let it idle for about a minute anyway, at least when it's cold. Quote Link to comment Share on other sites More sharing options...
Repsol Posted July 4, 2007 Author Share Posted July 4, 2007 once it settles, it idles at like 700 rpm. So i'm guessing it's fine. Quote Link to comment Share on other sites More sharing options...
TS John Posted July 4, 2007 Share Posted July 4, 2007 Yeah, that's right where mine settles at. Quote Link to comment Share on other sites More sharing options...
Repsol Posted July 4, 2007 Author Share Posted July 4, 2007 (edited) Man..you're sol is so clean! >_< Edited July 4, 2007 by Repsol Quote Link to comment Share on other sites More sharing options...
cranny Posted July 4, 2007 Share Posted July 4, 2007 under your throttle body , theres an FITV. take the 2 8mm bolts or screws holding the cover on , than retighten the plastic flat head screw. done. no more bouncy idle. Quote Link to comment Share on other sites More sharing options...
