Just2kos Posted July 1, 2007 Share Posted July 1, 2007 i need help i got a d16a1 with a brown top distributor i cannot get spark to my injectors can anyone help me out Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 1, 2007 Share Posted July 1, 2007 kinda confused here.You're not getting spark at the plugs or not getting power to th injectors ? Quote Link to comment Share on other sites More sharing options...
Kegger Posted July 1, 2007 Share Posted July 1, 2007 You need the distributor for the motor. You can't rock the brown top distributor as the computer can't run it. Quote Link to comment Share on other sites More sharing options...
Just2kos Posted July 2, 2007 Author Share Posted July 2, 2007 You need the distributor for the motor. You can't rock the brown top distributor as the computer can't run it. people on here said that it was possible to run the brow top distributor on a black top d16a1 i have the computer out of the integra what if i use the wire harness off it as well Quote Link to comment Share on other sites More sharing options...
Kegger Posted July 2, 2007 Share Posted July 2, 2007 Um you need the PM6 computer, out of an 88-91 CRX Si, that could be the reason for all your problems. Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 6, 2007 Share Posted July 6, 2007 d16A1 isn't that an early integra motor ? does it have an external coil ? Quote Link to comment Share on other sites More sharing options...
CRG7 Posted July 6, 2007 Share Posted July 6, 2007 yeah, d16a1 is a first gen integra engine. (dohc, non-vtec) Quote Link to comment Share on other sites More sharing options...
Just2kos Posted July 9, 2007 Author Share Posted July 9, 2007 yea the motor is out of a 1st generation integra it is external coil i just cant get no spark to my coil i think it has to do with the wires that come out of the distributor bc they arent their on the integras distributor maybe i need the motor wire harness for the d16a1 to make it run.... Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 9, 2007 Share Posted July 9, 2007 yea the motor is out of a 1st generation integra it is external coil i just cant get no spark to my coil i think it has to do with the wires that come out of the distributor bc they arent their on the integras distributor maybe i need the motor wire harness for the d16a1 to make it run.... see if your getting 12 volts going to the (+)coil with the ignition in the ON positon. If you do,crank the motor and on the (-) side of the coil put a test light there.The test light should blink ON and OFF . If it don't blink ,and your getting 12 volts @ the (+) side, coil is bad.If no 12 volts what so ever,you'll have to trace the wire back. Quote Link to comment Share on other sites More sharing options...
Just2kos Posted July 10, 2007 Author Share Posted July 10, 2007 see if your getting 12 volts going to the (+)coil with the ignition in the ON positon.If you do,crank the motor and on the (-) side of the coil put a test light there.The test light should blink ON and OFF . If it don't blink ,and your getting 12 volts @ the (+) side, coil is bad.If no 12 volts what so ever,you'll have to trace the wire back. thanks ill give that a try tomarrow Quote Link to comment Share on other sites More sharing options...
Just2kos Posted July 10, 2007 Author Share Posted July 10, 2007 thanks ill give that a try tomarrow on my previous comment i put i had no spark to my coil i ment to my injectors i got spark to all my plugs just nothing to my injectors to shoot the gas into the car.. i was told that the wires for the injectors run off the computer but i think it has to do something with the wires for the distributor ( thats y i am thinking i need a harness for and integra that may have them wires hooked up differently since their are no wires comming off the distributor... Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 10, 2007 Share Posted July 10, 2007 oh, then check the main relay.see if theres power there.should hear a click when you first turn the key ON. check your fuses too. Quote Link to comment Share on other sites More sharing options...
eg9-civic Posted July 11, 2007 Share Posted July 11, 2007 um i think you need to connect/unconnect a injector resistor box. forget which one it is. Quote Link to comment Share on other sites More sharing options...
