cash motorsports Posted June 30, 2007 Share Posted June 30, 2007 my break light fuse keeps blowing does anyone have a ideal of what might cause it cause i checked all the break wires and dont see a open wire, is there anything else hooked up to the same fuse as the break light fuse which is located under the hood. Quote Link to comment Share on other sites More sharing options...
CRG7 Posted June 30, 2007 Share Posted June 30, 2007 horn and if you have an auto, the shifter lock are the same fuse as the brake lights under the hood. are you using the right fuse? Quote Link to comment Share on other sites More sharing options...
cash motorsports Posted June 30, 2007 Author Share Posted June 30, 2007 horn and if you have an auto, the shifter lock are the same fuse as the brake lights under the hood. are you using the right fuse? yes the fuse is a 15 amp and i think it might be the shift lock that is blowing it Quote Link to comment Share on other sites More sharing options...
crxtacy Posted July 1, 2007 Share Posted July 1, 2007 when does the fuse blow ? as soon as you insert the fuse ? when you depress the brake pedal? etc .. Quote Link to comment Share on other sites More sharing options...
cash motorsports Posted July 2, 2007 Author Share Posted July 2, 2007 Im not sure when it blows the lights will work for a few min when i put the fuse in but a few mins after i start driving then it blows i had a friend drive behind me and called i didnt even make it 5 min down the road when they blow out. I dont have a horn it was disconnected when the front end work was done but that was 9 months ago i think it is the shift lock doning it and i am thinking bout taking it off to see what happens Quote Link to comment Share on other sites More sharing options...
TS John Posted July 4, 2007 Share Posted July 4, 2007 If your horn was disconnected bet the wire to it is grounding on something and blowing your fuse. Quote Link to comment Share on other sites More sharing options...
