H22 or b18c5
well the H22A is the prelude engine, it is 2.2L so its bigger, the typs S model gives you ~220 HP and the regular gives you ~190 HP.  Where the B18C-R gives you 200 and is only 1.8L.  The H22 will fit in a Civic but there are a lot of problems with making it fit that it might not always work out good, If you have a civic I suggest you go with the B18C but if you have a prelude go with the H22<=== more bang for your buck in a prelude
which engine would be in a 91 prelude si?
i was looking at one the other day that was in excellent condition and the owner was only asking $1800.
220 hp from a 2.2L is incredible
hi
i was wondering wut kind of car ur putting this motor in.  If its a civic id go with the b18c5 cuz it will be a lot easier to mount than a h22 because its the same series.  If ur going to put it in an accord, i suggest that u use the h22 because i've heard it fits better.
the new prelude engine H22 5 speedcomes with 200 HP
and the automatic is the one that comes with 190 HP
H22 is a great engine if you are planning on turbo charge your car it has lots of torque at very low RPM while the B18C5 has a smaller displacement which means less torque the B18C is a great engine for NA vehicles you can get amazing HP numbers with a B18C But like I tell my custumers is mostly a preference the H22 swap however on a civic means some custom fabrication while the B18 is almost a direct swap.
  • 3 months later...
go wit the itr motor anyway. even if u had a prelude sell it and ghet a civic or crx or del sol or teg. preludes weigh to much and cost a lot to make fast becasue they weigh so muhc. i personally like the itrs becasue they are kinda cheap and really fast and if u get teh right combo between itr and car u will be unstopable
  • 1 year later...
