b16
matchboxboy69
Posted
ok my friend is giving me his b16a2 but hes keeping his harness its obd0 and i have a non vtec obd1 harness and comp will it work with the vtec motor??
Posted
If you get a P28 ECU out of an EX or Si and wire VTEC you're straight.
Posted
The b16a2 is obd2. If you mean his car is obd 0 and he is keeping his harness, and you are using your obd1 harness, most of your plugs will work. You will have to change the alternator and dizzy plugs...if you keep it obd1 you should only have to add sensors for teh vtak.
If you use a p28, you will need to get it chipped for it to run properly. Use a OBD1 p30. I also happen to have an OBD1 p30 for sale...
Posted
use punctuation....your English teacher must have been very upset with you.
