AZ_Ger1107 Posted May 14, 2007 Posted May 14, 2007 After noon, I have a problem and I really need help, this is making me very angry when I hit my power lock button my diver side door dosent lock, however when you lift up the handel it will lock manualy, and when the door is closed the automatic works. Then with the key, I can't unlock my door with my key it seems to be stuck. Can anyone help me as of how to fix this problem please!!!!! :help:
..SSR.. Posted May 14, 2007 Posted May 14, 2007 My drivers side (manual) I have to pull the handle inside to lock it. Unlocks normal. Works normal from the outside.
adamEj6 Posted May 14, 2007 Posted May 14, 2007 they dont lock when the door is open unless you pull the handle then lock it
CRG7 Posted May 14, 2007 Posted May 14, 2007 After noon, I have a problem and I really need help, this is making me very angry when I hit my power lock button my diver side door dosent lock, however when you lift up the handel it will lock manualy, and when the door is closed the automatic works. Then with the key, I can't unlock my door with my key it seems to be stuck. Can anyone help me as of how to fix this problem please!!!!! :help: You have to pull the handle to lock the driver's side door from inside the car (with the door open), whether you're pressing the button or manually pushing it over to lock.
brynfiv Posted May 16, 2007 Posted May 16, 2007 I don't have power locks, but I have the same problem in my 98' CX. It would lock without pulling the door handle until somewhere around 90,000 miles. I've just accepted it, but I'm sure it would be annoying pain with power locks.
