jetguy84 Posted May 12, 2007 Share Posted May 12, 2007 Okay so this problem has me scratching my head. My wife gets in the car, cranks it up and starts to pull out of her parking spot. She forgets something in her classroom and pulls back into her spot, runs inside for 2 minutes then when she gets back in the car it will not start....My first guess was the timing belt let go. Belt is intact, inspection of fuel pump shows its working. After working towards the engine from the fuel tank I have discovered there is no spark to the plugs. My question is has nyone seen or heard of this type problem. If so where would be a good start in troubleshooting the ign system? Any and all help will be greatly appreciated..Thanks, Keith Link to comment Share on other sites More sharing options...
Hatch92 Posted May 12, 2007 Share Posted May 12, 2007 sounds like the coil is breaking down. it's not creating enough power to cause the spark. sounds like the coil is breaking down. it's not creating enough power to cause the spark. Link to comment Share on other sites More sharing options...
Spoonkid Posted May 15, 2007 Share Posted May 15, 2007 I agree, ignition coil Link to comment Share on other sites More sharing options...
crxtacy Posted May 28, 2007 Share Posted May 28, 2007 remove distributor cap and inspect for anything obvious.get a test light and put it on the neg. side of the coil.have someone crank it and see if the test light blinks.if it does,the coil is bad.if it just stays on,the igniter is bad . Link to comment Share on other sites More sharing options...
