a/c problems
Jedikid
okay i have a problem with my ac. i put in that stuff to make the air cold again. well my ac is working great but when i turn it on it seems to cut my engine off an instant about every 3-4 seconds. anyone know why. but the car runs great with it off
yeah it seems the engine dies about every 3-4 seconds. i lose all power in the motor for just a second. but as soon as i turn off the a/c. my cars fine.
so when u have your ac on your engine has less balls? go figure. ac is added stress on the system, some thing else for the motor to turn so your goann feel the power loss.
okay well i was just in school saying what ya'll had to say
i'll go to the shop tonite and see what the problem is
a/c is overcharged.too much refrigerant would cut the engine.try hooking up the a/c gauge .bet the pressure is way over .
LOW SIDE : 15-30 PSI
HIGH SIDE : 175-200 PSI
depends on how hot the weather is there.
And you figure this how?
This is a definite possibility. Could also be a clogged/stuck expansion valve. I've had this happen twice (at least I think that's the current problem).
I agree on the gauge, although read the low side first. It should stay pretty constant. If the pressure builds, you've probably got a clog in the system. Mine keeps cycling the compressor every few seconds as the pressure builds and kills one of the pressure switches.
