xer0 Posted May 6, 2007 Share Posted May 6, 2007 besides the engine what need to be changed to get a s up to a si is there more then just the breaks, power locks, suspension, wheels, abs, power staring? Link to comment Share on other sites More sharing options...
Kegger Posted May 6, 2007 Share Posted May 6, 2007 Nope you've got all of it. But just swap the motor nobody needs any of that extra crap, it just adds weight. Link to comment Share on other sites More sharing options...
xer0 Posted May 6, 2007 Author Share Posted May 6, 2007 but i am a babie i want abs and power locks and power staring and dics brakes. so what if abs only came on the vtec trim Link to comment Share on other sites More sharing options...
Kegger Posted May 6, 2007 Share Posted May 6, 2007 Then it's gonna cost time and money. Lots of it. Link to comment Share on other sites More sharing options...
xer0 Posted May 6, 2007 Author Share Posted May 6, 2007 well i am singla agian so i will ahve tie and money.... well when i get back form training Link to comment Share on other sites More sharing options...
Kegger Posted May 6, 2007 Share Posted May 6, 2007 Well if you are gonna have all the money just buy an Si. Link to comment Share on other sites More sharing options...
xer0 Posted May 6, 2007 Author Share Posted May 6, 2007 i kno, but i just find s models in good condition all the time. i usaly find liek 93 94 si with an auto. found a 95 vtec but the guy sold it the day before i called :( Link to comment Share on other sites More sharing options...
Hatch92 Posted May 6, 2007 Share Posted May 6, 2007 to put ABS in the S it's gonna take alot ot time to wire the sensors and to pin the ECU. there's more to it then just puttin ABS brakes and now you have ABS. you'll need ECU with ABS, sensors, wireing diagram and wires, then you have to buy the brakes, axles, etc. new axles because most ABS systems run on either the notches cut in the wheel bearing or the axles has the notches. they tell the ecu when the tire is locked up and when to engage the ABS. Link to comment Share on other sites More sharing options...
TS John Posted May 6, 2007 Share Posted May 6, 2007 I've never once missed ABS on my sol. Guess you only need it when you really need it, though. Link to comment Share on other sites More sharing options...
Kegger Posted May 6, 2007 Share Posted May 6, 2007 No need for it, plus you really can't feel the brakes when the pedal is pulsing at you. Theres no real response that REAL drivers look for. LOL Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 6, 2007 Share Posted May 6, 2007 I have a rear sway bar from an SI I will sell you. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 7, 2007 Share Posted May 7, 2007 Other than the motor difference, it's retarded. I bought the S because I don't care about Cruise Control, disc brakes in the rear, the wing, or the rear sway bar. Not all SI's have ABS though, or PDL's. My buddy has one, and it sure as hell doesn't have it. Link to comment Share on other sites More sharing options...
airjordan223 Posted May 7, 2007 Share Posted May 7, 2007 it would be cheaper to find a clean si across the country and ship it to you, then buy an s where you are and change everything over Link to comment Share on other sites More sharing options...
JapaneseDomesticMarketGSR Posted May 8, 2007 Share Posted May 8, 2007 I have a rear sway bar from an SI I will sell you. You should jump on that OP. You will notice a major difference in handling. Very simple to install too. All you need is the sway bar, endlinks, and lcr's. You should also look into purchasing a rear beam brace for the front, vast improvement. Link to comment Share on other sites More sharing options...
SolLesHonda Posted May 8, 2007 Share Posted May 8, 2007 Rear beam brace for the front? WTF? If you're going to get a sway, get the 22 or 23mm ITR sway with ASR subframe brace. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 8, 2007 Share Posted May 8, 2007 I did....thats why I have this one for sale....lol. Link to comment Share on other sites More sharing options...
JapaneseDomesticMarketGSR Posted May 8, 2007 Share Posted May 8, 2007 Rear beam brace for the front? WTF? If you're going to get a sway, get the 22 or 23mm ITR sway with ASR subframe brace. Ya, a rear beam brace for the front. Do some research, genius. Maybe you should just ask your dad, he should know. From your pics it looks like he is the one who did your tranny swap. P.S. I knew I shouldn't have clicked that button that says view ignored users post. Link to comment Share on other sites More sharing options...
zimmy709 Posted May 17, 2007 Share Posted May 17, 2007 Nope you've got all of it. But just swap the motor nobody needs any of that extra crap, it just adds weight. yea exactly what he said... and if you are swapping, put something like a b series in, it's pretty much the same amount of work and you will be much happier, i pulled my d16z6 out.. its really not worth putting one in unless you wanna do a d series boost monster or something silly <------ Link to comment Share on other sites More sharing options...
