jjcuff1 Posted May 5, 2007 Share Posted May 5, 2007 Ok car drives great for $500. Clutch feels a little weak but OK. engine bay is immaculate for age and looks clean and runs strong, slight rough idle but still needs tuneup. shifting is great, ac is cold, all power windows work drivers window looks misaligned. i guess remove door panel and line up? or replace tracks? center console box is ripped out and broke, I need to replace center console? carpet is trashed, I figure remove seats and door sills and I can rip it up? and replace? same with trunk? any good places blinkers do not appear to work but flashers work inside car on dash and outside in bulbs. I figure dual filament is burned out or fuse? rpm gage does not work. where is the pickup? how much for a clutch and a timing belt (to be safe) Link to comment Share on other sites More sharing options...
Kegger Posted May 5, 2007 Share Posted May 5, 2007 1. For the windows, just straighten the tracks out. 2. For the blinkers, check the fuse first before you replace bulbs. 3. Tach wire is a little blue one coming from the distributor. 4. Clutch can be any where from 100 to 250 if you go after-market, but at like Autozone they're prolly gonna be about 100. Timing belts are like 25 to 50 depending on where you go. Link to comment Share on other sites More sharing options...
TS John Posted May 5, 2007 Share Posted May 5, 2007 What a deal for that car. That's nothin'... Wish I had gotten a white sol for 500 bucks that runs... Link to comment Share on other sites More sharing options...
