WTF: I'm Lost.
Ok, It hit me. I just got my car and the block says d16z6. I look on the internet and i noticed that the d16z6 spark plug holes are close to the header and the oil cap is in the top right. But on my car the spark plugs are close to the intake manifold and the oil cap is in the lower left. How is this Possible? Srry for the amount of posts.
it would fit, its a d16 block regardless, the question is why though? people normally put z6 heads on so they can have vtec and get more power but from what your saying they've done the opposite?
I don't know what the man did. The manifold, header, and everthing else looks identical to the z, just the valve cover. I just wondering what i'm losing off the car since this is the case. I mean how much does this affect? VTEC, etc. The manifold, header, and everthing else looks identical to the z, just the valve cover.
What do i have to remove the curse?
What head should I put on? Isn't there a dohc, I can put on? I'm not sure what car model I have Everything is powered, no wing or anything. So I dunno.
You can't put a DOHC on a SOHC.
A6 head on the Z6 would result in lower compression.
Just get a Z6 head and call it a day.
Dude you have Z6 everything and an A6 head. Buy a Z6 head and swap out heads. Then you have a nice strong motor with VTEC and it cost less than $400.
