Help, crx b16a wiring problems
carboncrx
Posted
Ok so i recently removed my engine (b16a) and i put it back in but there is something really messed up. I go to turn my lights on and the engine dies, none of my flashers or brakelights work, and if i put the car in reverse, the engine wants to cut out on me. SO i need a lot of help!
Posted
was it everything working normal before ? were you running the B16 motor before you took it out ?
check the wiring harness by the fuse box under the hood .Check ALL tour grounds !!
