engine problem
ArtyMillz
listen i have an oil leak but its realll small but sometimes the car will bog out and stall and the oil light will flicker but when i checkk the oil theres the perfect amount in there.....what could be causin the car to do this?
your oil pump is failing possibly. your oil filter could be plugged , but if you change oil regularly i doubt this is the cause. i would say , dont drive that car anymore till you put an oil pump on it. if it goes and you dont notice it fast enough , POP.
were is the oil coming from??? (maybe i missed that)
are u sure the reason the engine "bogs out" is from the oil leak? Cause since the car is older the oil leak and the engine bogging might be two different problems...just a wild guess :-
