wragen22 Posted May 1, 2007 Share Posted May 1, 2007 I get a creak in my left wheel base somewhere when turning at very slow speeds. It usually happens when turning left at a stop sign. Any ideas as to what this could be? Anything serious? Could it be fixed? The car was in an accident. Link to comment Share on other sites More sharing options...
T-70 Posted May 1, 2007 Share Posted May 1, 2007 I get a creak in my left wheel base somewhere when turning at very slow speeds. It usually happens when turning left at a stop sign. Any ideas as to what this could be? Anything serious? Could it be fixed? The car was in an accident. well it could be your lower ball joint or upper. it could be your outer or inner tie rod end if you can lift the car and check for wheel rock. check your struts and strut mounts. check your hub bearings Link to comment Share on other sites More sharing options...
cranny Posted May 1, 2007 Share Posted May 1, 2007 its probably an upper or lower balljoint. and if its sqeaking , it needs attention. Link to comment Share on other sites More sharing options...
wragen22 Posted May 1, 2007 Author Share Posted May 1, 2007 I also notice that the car lurches quite a bit, mostly towards the right front end of the car, when on the freeway taking dips and bumps from bridges ect. Could this be something related? Link to comment Share on other sites More sharing options...
T-70 Posted May 1, 2007 Share Posted May 1, 2007 I also notice that the car lurches quite a bit, mostly towards the right front end of the car, when on the freeway taking dips and bumps from bridges ect. Could this be something related? could be your struts Link to comment Share on other sites More sharing options...
wragen22 Posted May 2, 2007 Author Share Posted May 2, 2007 could be your struts You guys were right. Left, front strut is bad. Thanks for all the feedback. Link to comment Share on other sites More sharing options...
T-70 Posted May 2, 2007 Share Posted May 2, 2007 You guys were right. Left, front strut is bad. Thanks for all the feedback. not a problem thats why we are here to help out. Link to comment Share on other sites More sharing options...
