EH6TunerDaniel Posted April 30, 2007 Share Posted April 30, 2007 My cruise hasnt worked for a while. I read Hung's thread from a while back, but my problem is not the same as his. The fuses are good, I have 2 switches to turn on the cruise, one to push to turn the system on, and one to set it. The light on the switch to turn the system on does not come on....Any Ideas. Link to comment Share on other sites More sharing options...
koffeeDC2 Posted May 1, 2007 Share Posted May 1, 2007 i got an idea next time i come into town we can try my switch on it and see if that is the problem Link to comment Share on other sites More sharing options...
TrailMystic Posted May 1, 2007 Share Posted May 1, 2007 Glad this thread was started because my cruise control on my one month old sol doesn't work either. Same situation - switch to turn it on doesn't illuminate. If it has the swtich, I assume it has cruise control. Pete Link to comment Share on other sites More sharing options...
cranny Posted May 1, 2007 Share Posted May 1, 2007 did it work fine before engine swap EH? if so just go over the wiring for it. might just need power or somin stupid. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 2, 2007 Author Share Posted May 2, 2007 Go frackk yourself James. Cranny, it didnt work before the swap, but it did work when I got the car. No blown fuses, Im confused. Link to comment Share on other sites More sharing options...
redcoats1976 Posted May 2, 2007 Share Posted May 2, 2007 most interstates have a 70 mph limit,but plenty of people cruise around 90 or so. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 3, 2007 Author Share Posted May 3, 2007 I have a 70 mph drive for an hour to and from school each day. It is heavily patroled and hard to keep from speeding. Link to comment Share on other sites More sharing options...
cranny Posted May 3, 2007 Share Posted May 3, 2007 hard to say EH , im sure you downloaded your manual by now , see if theres a trouble shooting process for testing your cruise control unit itself. maybe its toast. have you ever disturbed it? should be a black box mounted under your hood with a throttle cable basically comming from it and going into your firewall usually. Link to comment Share on other sites More sharing options...
EH6TunerDaniel Posted May 3, 2007 Author Share Posted May 3, 2007 I downloaded the manual and found the circuit. It goes through toooooooo much crapt. It stopped working when my brake lights were stuck on, and I had to turn the sensor that tells if the lights are pressed....Im not sure if that messed with it, but I would think the light on the switch itself would still come on if that was the case... Link to comment Share on other sites More sharing options...
cranny Posted May 3, 2007 Share Posted May 3, 2007 perhaps not though , look when you install a deck into some cars , the interior lights go out cause the wiring for the interior lights goes through the deck , lol. Link to comment Share on other sites More sharing options...
