best turbo
jeffthenaef
idk if they let us post liks to other sites so ill just give the info on the turbo im looking at,I want to put this on a 2001.
I was looking at this stage 3 rev-hard, but it does not give info on the cars it works on.
I know this says track only but I will probly not be visiting the track to much, this will be the second mod i put on the car (the first being some nice brakes.) What do we think?
Stage: 3 HYPO Kit
Use: Track
Part No.: RHHYPO
MSRP: starting $4,999.99
Boost Level: 15+ PSI
Injector Size: 990cc LI (Optional)
Horsepower/Torque: 550+ / 395 ft/lbs
Rev Hard Tubular Manifold
Premium Hypo Turbo(650+hp)
Rev Hard Intercooler (29" x 10" x 3.5")
Tial Wastegate (9-12 PSI)
Rev Hard Blow Off Valve
2.5" Aluminum Charge Pipe
2.25" Aluminized Mandrel Bent Piping
2.5" Downpipe
High Volume Fuel Pump
1:1 Fuel Pressure Regulator
Silicone Hoses & Clamps
Steel Braided -3 Oil Line
Oil Return Line
Necessary Vacuum Lines
Necessary Vacuum Tee's
Optional Upgrades
Mild Steel Equal Length Manifold
3" Downpipe
990cc Injectors
AEM EMS Upgrade
Ball Bearing Turbo Upgrade
Stage 3 Kit must be used with Engine Management System.
I guess my advice depends on whether you want to create a time bomb or a fast Honda. Right now it's looking like the first.
well this is my first turbo, so I don't know what i'm doing. and I dont think I want a time bomb.
