1994 Accord Amp Wiring
i helped my friend install one on his 94 accord. there should be a rubber plug with wires going through it above the clutch pedal to the left. use a screw driver or something to poke a hole in it to get the wires through
I did mine close to there. I went from the batery to the driver side along the firewall, then I had to drill a hole into the firewall right above the break pedal (I have the auto), wasn't hard. I ran a 4 gauge wire so it did not fit where that plug was, so i just drilled a hole beside it and threw some silicone on it wire, then went down into carpet where the bottom paneling is located under the door. This was actually one of the easier cars I have done. If I had a camera I would show you.
