carboncrx Posted April 30, 2007 Share Posted April 30, 2007 So i got the clutch and everything all done. i put the engine back in and hooked up my wiring harness, but must have messed something up because i started it up and the rpms started pulsing quick, then i reset the ecu, got it to work for a while. then shut it off and it started pulsing again, now it bogs doen when i try to rev up the engine. So any suggestions are welcome, thanks Link to comment Share on other sites More sharing options...
dohc1991integra Posted April 30, 2007 Share Posted April 30, 2007 So i got the clutch and everything all done. i put the engine back in and hooked up my wiring harness, but must have messed something up because i started it up and the rpms started pulsing quick i didnt think u needed to remove the engine when replacing the clutch??? i got my trans out by just tilting the engine a lil bit...are crxs different or something do the rpms return to normal when u drive it? Link to comment Share on other sites More sharing options...
carboncrx Posted May 2, 2007 Author Share Posted May 2, 2007 i didnt think u needed to remove the engine when replacing the clutch??? i got my trans out by just tilting the engine a lil bit...are crxs different or something do the rpms return to normal when u drive it? the rpms are fine now i fixed that, but know i have another great problem, my gauges dont light up, none of my lights work, and when i go to turn my lights on, it kills the engine. So i need major help Link to comment Share on other sites More sharing options...
