rims & body kits
jjcuff1
What size can you go without doing camber work? 16"
I like the 5 spoke square, blocky rims that look like bars then in the middle they recess into the hub. Just like on the new rx8 and 350z. did see anything that fir the del sol on tirerack or direct.
what size hub does the s del sol have (rear drum)
Where are some links to non batman body kits? I have to get my car painted. Is it recommended to install body kit and paint whole car or leave kit off, paint it, then install?
any good junk yard, honda parts yards in tampa? i might need to buy a center console
rim size doesnt affect your camber. when you change the height of the car, such as lowering it with new springs or coilovers, it can affect your camber.
they only 5 spoke similar to what youre talking about that ive seen on a sol are these
i believe they are from a cobalt.
check out wheelsnext.com and wheelmax.com for a bunch of different rims.
the mugen body kit is pretty clean but $$$ so buying a knockoff would be better if you like that. also kaminari looks good, its pretty expensive as well, but you wont have to modify it at all to get it to fit. the best way to paint is before you install it on the car so you can get all the weird angles
i havent had much luck finding junkyard stuff for my sol here in lakeland...
man do i like that sol. :drool:
for wheels also try edgeracing.com, dicounttiredirect.com, tiresdelivered.com, or just google wheel and tire packages....the list is endless :thumbsup:
