newkidwithsol Posted April 27, 2007 Share Posted April 27, 2007 Any help from anyone will be very helpful. To start out I bought a 93 del sol si. B18B1 swap, tranny out of a RSX. Short throw sifter, ect. Do I still have the stock computer? Can I hook up a diagnostics computer to it? Would the check engine light still work? Now a real brain BUSTER...... My car now has a low idle, Exhaust is lower(deeper) not as raspy. I do have a fart can on it. No matter if I am accelerating or just a steady cruise, it will bog down untill i give it more gas, like to the floor. If I take my foot off of the gas pedal and not push in the clutch, It don't pop (exhaust). It use to. What is wrong??? Thanks for your time. Victor Link to comment Share on other sites More sharing options...
1.7gsr Posted April 27, 2007 Share Posted April 27, 2007 Any help from anyone will be very helpful. To start out I bought a 93 del sol si. B18B1 swap, tranny out of a RSX. Short throw sifter, ect. Do I still have the stock computer? Can I hook up a diagnostics computer to it? Would the check engine light still work? Now a real brain BUSTER...... My car now has a low idle, Exhaust is lower(deeper) not as raspy. I do have a fart can on it. No matter if I am accelerating or just a steady cruise, it will bog down untill i give it more gas, like to the floor. If I take my foot off of the gas pedal and not push in the clutch, It don't pop (exhaust). It use to. What is wrong??? Thanks for your time. Victor im not to shure about everything elese but if u hav a stock exhaust on that it might hav to much back presure if the piping is small Link to comment Share on other sites More sharing options...
cranny Posted April 27, 2007 Share Posted April 27, 2007 first of all , you cant have a b18B1 swap and a tranny out of an rsx. take your dizzy cap off and make sure your rotor is tight and in tact. in fact , do yourself a favor if your not sure how old it is , and replace it. other than that , could be a dizzy going sour , a number of ignition components. Link to comment Share on other sites More sharing options...
newkidwithsol Posted April 28, 2007 Author Share Posted April 28, 2007 Cap and rotor still look good, I will replace anyways. Any other Ideas I could try? Link to comment Share on other sites More sharing options...
newkidwithsol Posted April 28, 2007 Author Share Posted April 28, 2007 What about a modified cap that uses an external coil? Will that help solve my problems? Link to comment Share on other sites More sharing options...
Kegger Posted April 28, 2007 Share Posted April 28, 2007 Probably not, have your distributor tested, to make sure its doing everything it should be doing correctly. Link to comment Share on other sites More sharing options...
newkidwithsol Posted May 14, 2007 Author Share Posted May 14, 2007 Finally got my car fixed!!!! It was a battery clamp, and a few ground wires. I repalced all of that and now runs beautiful again!!!! Thanks for all of your help!!! Link to comment Share on other sites More sharing options...
