temp guage jumpin...
any white smoke?
could be the fan switch on the back of the block....
might just need a coolant flush, if air is in the lines = overheat.
if you're low on coolant that could cause it.
worse case, you have a blown head gasket like i did.
any white smoke?
i do have smoke...i think the smoke is form the rear main leak it had (oil blow back) so i bought some engine degreaser today to see if its old blowback still burnin or white smoke like u say.
we just flushed the not to long ago and then when we did all the maintenance stuff we flushed it again
wat does the fan switch do?
