carboncrx Posted April 22, 2007 Posted April 22, 2007 Help, i need to replace my clutch in my 89 crx w/ b16 swap, what is the easiest way to replace it? I tried to pry ball joint apart on my a-arm to give me more play but it wont budge. So if anyone has done this or knows a site w/ the how-to please let em know
JapaneseDomesticMarketGSR Posted April 23, 2007 Posted April 23, 2007 Help, i need to replace my clutch in my 89 crx w/ b16 swap, what is the easiest way to replace it? I tried to pry ball joint apart on my a-arm to give me more play but it wont budge. So if anyone has done this or knows a site w/ the how-to please let em know Put the jack under the ball joint and jack it up slowly while hitting it with a 5lb hammer. there is a metal tab on both sides where you should be hitting it. If you get the jack at the right height that biatch will break free.
