Anyone interested in a hybrid trans?
So I'm picking up an Z6 and Y8 trans next week. Going to replace the ISB/seal, and axle seals, as well as any bearings that need to be replaced. Gear cones will be scuffed and ISB staked. ZC 3-4-5 gears with stock 1-2 and FD.
Not including any additional bearings that need to be replaced each would be $600 plus shipping (will deliver for gas + the amount of Mountain Dews I drink enroute). $100 deposit via Paypal required to hold trans, balance due upon completion of trans. If you already have a trans I'll build that, but the labor I am charging for these is a lot less than normal.
Can also include an MFactory final drive and retain stock 5th gear, or MFactory gearset versus ZC gearset.
For anyone with a cable trans, I will be able to install the ZC 1-2 gears though there isn't a big difference (1.944 2nd versus 1.900 stock, 1st is the same).
Will only be picking up a Y8 and Z6 trans. Have someone local interested in the Y8 trans but its nothing solid yet. If I have deposits on both of these by Friday, $550/each and free MFactory magnetic drain plug.
LOL. I'm just not seeing it, with the setup I'm hunting. Bolt on GSR swapped EG hatchbacks here in town seem to be running high 13's as a norm, for some odd reason. I feel out of the loop.. I wanna' see if they're BSing and have cams or not. Either way, I gotta' get a car..to start with.
