TJPT Posted April 21, 2007 Share Posted April 21, 2007 Help!!! I was in the process of changing my winter tires over to summer tires and one of the front left wheel lugs snapped. Can anyone help me with the procedure to replace it? Thanks...Tim Link to comment Share on other sites More sharing options...
airjordan223 Posted April 21, 2007 Share Posted April 21, 2007 was it just a lug nut? Link to comment Share on other sites More sharing options...
JapaneseDomesticMarketGSR Posted April 21, 2007 Share Posted April 21, 2007 Your fracked. It's fixable but you will need tools and a press. This happened to me on my integra. I just dropped the whole arm including the hub. Took it to the shop and pressed out the old stud and pressed in the new one. I am not sure if you have a five lug or four but if it is a five lug then you should be ok with one stud broken. It's on you. Link to comment Share on other sites More sharing options...
Kegger Posted April 21, 2007 Share Posted April 21, 2007 If it was a stud you have to pull the hub, pound out the old one and then press in new one. Edit: You can do it in your front yard if you have a slide hammer. Link to comment Share on other sites More sharing options...
