inmate Posted February 19, 2007 Posted February 19, 2007 Anyone has a light problem like i do? My right headlight works fine but not my left headlight the other (it turns on but dim). i change the light socket and new bulb but it still not lighting that bright as the other one . Help!!! Can't be the fuse cuz the light does turn on
willthiswork89 Posted February 22, 2007 Posted February 22, 2007 sounds like a ground problem to me, most lights have a shared ground and when the ground gets disconnected from one side, it still lights but it dimmer then the one with striahgt ground, check for that first man.
inmate Posted February 23, 2007 Author Posted February 23, 2007 sounds like a ground problem to me, most lights have a shared ground and when the ground gets disconnected from one side, it still lights but it dimmer then the one with striahgt ground, check for that first man. when you say grounding problem...what exactly does that mean...the cable is burned?...um losing volt sumehow? i should check the wires?
