kingazn1 Posted February 19, 2007 Posted February 19, 2007 When I pull the Hood release, nothing happens, it just recently happened. Is there any possible reason that the cable can freeze? or is it just broken? the temp has been -5 to 5 degrees celcuis. Please help, thanks i have a 96 civic dx 4dr
Blizzard Posted February 19, 2007 Posted February 19, 2007 Yeah, the cable or the latch itself can freeze or break. Try to thaw it out (warm garage), and if that doesn't work, lift the lever and pull on the cable with a pair of pliers. If it moves freely, it's probably broken.
Verbal Killa Posted February 19, 2007 Posted February 19, 2007 I have the same problem. pop the hood by going under the car and movin the clip.
cranny Posted February 20, 2007 Posted February 20, 2007 yeah verbal got it , just reach up between rad and front support , and pull the cable.
Kastigir Posted February 20, 2007 Posted February 20, 2007 Those cables do stretch. I've had to replace one already, and I think I'm going to have to again. I might just get some damn hood pins this time.
