tegrakid06 Posted February 18, 2007 Posted February 18, 2007 i was looking in to building a poor mans type r i was wondering what all do u need for the build and do u get as much hp and tq as a type r
Nancy Posted February 18, 2007 Posted February 18, 2007 you need a b18c1 (gsr) block as is it is identical to an itr block but use the itr crank, rods, and pistons (p73). as for the head you can use any b16 head with itr or ctr cams and valve train. and run a p73 (itr) ecu. or if you decide to use and obd1 b16 head id use a chipped p28 if you are on a budget.
tegrakid06 Posted February 18, 2007 Author Posted February 18, 2007 do i need the itr intake to or will the gsr work or just get a b16 intake what would be the best tranny for it also
Nancy Posted February 18, 2007 Posted February 18, 2007 do i need the itr intake to or will the gsr work or just get a b16 intake what would be the best tranny for it also no, gsr intake manifold wont bolt onto the b16 head. i suggest getting the oem itr arm and box. but it depends on what car the engine is going into as well.
..SSR.. Posted February 18, 2007 Posted February 18, 2007 Just use a GSR head. Makes power sooner, better for street driving. Can also run more compression with less chance for detonation.
