auto to manual tranny conversion
xanswerx
Posted
how hard is it to convert a car with an auto transmission on it to manual? Im lookin to do it on a 95 civic ex and I need to know what parts i need to get..
Posted
I did in my DA....
Upgraded Parts I used:
B16 Cable Trans
Clutchmasters Stg 1 clutch
Clutchmasters Stg 1 PP
Clutchmasters Throw-out bearing
Clutchmasters 8 lb flywheel
B&M short throw shifter
Mandatory Parts:
pedal assembly
throttle cable
clutch cable (i dunno if you're cable or hydro)
shift linkage
shift rod
clutch cable brackets (2 on VC and one on trans)
MT intake manifold
MT ECU
MT reverse plug (wire to reverse lights)
MT Cluster (optional, but much cleaner)
MT axles
Shifter Bushings
Check brake pedal pin and codder pins
Trans mounts
MT Starter Mounting Bolts (longer)
Shim PS Motor mount so motor is level (need a screw longer than OEM screw to do this)
Make sure you have ALL your tranny case bolts, i was missing 4 and had to order them
Plate for linkage mounting
ah it's late....that's all I can remember for now.
if you need more info just let me know...
i have a '95 Civic MT Pedal Assembly, which is a MUST, so $55 shipped if you want it.
