Buiding a B18C1 to handled 600WHP
Posted
600+hp B18C1 Crate motor
Engine & tranny
OBD1 JDM B18C long block & 97 LS Acura tranny
engine parts
BDL 70 mm throttle body
JG Edelbrock intake manifold
cam gears
type r cams
Super Tech valves, springs, & retainers
NEW OEM oil pump
NEW OEM timing belt
NEW OEM water pump
ARP head studs
NEW OEM head set
NEW OEM bottom end set
shop charge/assembly lube/chemicals
tranny parts
quaife LSD
Differential bearings
Engine build
sleeve block
bore & hone cylinders
hot tank block clean block thoroughly
wiseco coated turbo pistons
crower rods
line bore/hone rods & crankshaft girdle
properly match new crank bearings & rod bearings to right size
main studs
main girdle
balance/blue print/polish crank
install crank girdle
block comes with detailed sheet of build (balance and blueprint) total
Labor
dissassemble engine
dissassemble cylinder head
assemble engine
install cylinder head, cams, cam gears, adjust valves,valve cover
install intake manifold & throttle body
install oil pump, oil pan, timing belt, water pump, head studs
install all gaskets & seals
lap valves into seats, assemble valves,springs & retainers
grind valves & seats replace exhaust valve guides
dissasemble tranny,clean & install LSD, replace diff bearings
machine flywheel
About $11,000,including Labor!... not including turbo, fuel rail, and some other parts you'll need
Posted
:spam: :spam: :spam: :spam: :spam: :spam: :spam: :spam: and eggs
