BuiltB18C1 Posted February 8, 2007 Posted February 8, 2007 600+hp B18C1 Crate motor Engine & tranny OBD1 JDM B18C long block & 97 LS Acura tranny engine parts BDL 70 mm throttle body JG Edelbrock intake manifold cam gears type r cams Super Tech valves, springs, & retainers NEW OEM oil pump NEW OEM timing belt NEW OEM water pump ARP head studs NEW OEM head set NEW OEM bottom end set shop charge/assembly lube/chemicals tranny parts quaife LSD Differential bearings Engine build sleeve block bore & hone cylinders hot tank block clean block thoroughly wiseco coated turbo pistons crower rods line bore/hone rods & crankshaft girdle properly match new crank bearings & rod bearings to right size main studs main girdle balance/blue print/polish crank install crank girdle block comes with detailed sheet of build (balance and blueprint) total Labor dissassemble engine dissassemble cylinder head assemble engine install cylinder head, cams, cam gears, adjust valves,valve cover install intake manifold & throttle body install oil pump, oil pan, timing belt, water pump, head studs install all gaskets & seals lap valves into seats, assemble valves,springs & retainers grind valves & seats replace exhaust valve guides dissasemble tranny,clean & install LSD, replace diff bearings machine flywheel About $11,000,including Labor!... not including turbo, fuel rail, and some other parts you'll need
