1994 Integra engine swap
CasperrXX
Posted
so would there have to be high modification? See the thing is im goign to buy a new engine and i was juss going to get a b18b when i was talking to my friend he said why would you do that juss go for the b20
Posted
If you want the b20 block, might as well just do a cr/vtec setup.
Do a google search and you can find all sorts of information about cr/vtec setups.
Posted
any b-series engine will bolt right into a 94-01 integra but if you have a non vtec integra then youll need to wire vtec.
Posted
I forget but I think it's just wiring the solenoid..which..shouldn't be too bad.
