ajdevestator Posted February 5, 2007 Posted February 5, 2007 i was on hmotorsonline.com and i was planning on buying their jdm, b18c type r motor...its 4 grand, but before i spend all that money, i wanted to know if it would even fit in my 94 integra LS with a b18b motor in it already. i wanted to go either that route, or am i safer (instalation-wise) using their GSR motor, its a B18C 94-97 motor....the gsr motor comes with, -Motor - Hydraulic Tranny (S80, Y80) - ECU (P72) - Axles with Half Shaft - Shift Linkage - Stock Motor Mounts * - Alternator - Starter - Clutch - Flywheel - Intake Manifold - Exhaust Manifold - Fuel Rail - Injectors - Distributor - Engine Harness - Comes With All Sensors Needed - LSD Tranny (Optional +$300) and the TYPE R comes with, -Motor - LSD Hydraulic Tranny (S80) - ECU (P73) - Alternator - Starter - Clutch - Flywheel - Intake Manifold - Exhaust Manifold - Fuel Rail - Injectors - Distributor - Engine Harness - Comes With All Sensors Needed IM OPEN TO ALL SUGGESTIONS
EH6TunerDaniel Posted February 5, 2007 Posted February 5, 2007 Get the ITR, but you will need the full swap. It would be the same (installation wise) as a gsr, but you will need a conversion harness for the ecu.
Kegger Posted February 5, 2007 Posted February 5, 2007 The only difference install wise is that the GSR is OBD-1 and the Type-R is OBD-2.
ajdevestator Posted February 5, 2007 Author Posted February 5, 2007 so all i need to get basically for the ITR swap is just the ecu harness?
Kegger Posted February 5, 2007 Posted February 5, 2007 Yeah or you could just run an OBD-1 ecu like a P28 or P30
ajdevestator Posted February 6, 2007 Author Posted February 6, 2007 how much do those conversion harnesses run? and would ebay be too risky to get one? is anyone selling one?
EH6TunerDaniel Posted February 6, 2007 Posted February 6, 2007 Uhh, click the link in the post right above yours.
Kegger Posted February 6, 2007 Posted February 6, 2007 74 dollars according to the link above your post.
ajdevestator Posted February 7, 2007 Author Posted February 7, 2007 also, random question....for a LS b18b engine...how much would a tps sensor run me? and do you know where i can get one/if anyone is selling one?
mycarsux Posted February 7, 2007 Posted February 7, 2007 junkyard, idk exact price but its most likely cheap
